1 - 7 of 7 Posts
What, painting? I don't see what you're looking at.
Take valve cover off, use aircraft stripper to remove old paint, primer, paint. I rattle canned mine, then sanded down the fins to expose metal, and clearcoated over the whole thing. Looks pretty good imo.
the valve cover originally comes with like this stuff on it that looks like rhino liner so would i just have to sand all that off?
there are a bunch of people that powder coat and that shit is legit what ima do is buy another one have tat one powder coated and swap it on my car
Aircraft stripper removes the paint chemically, the old paint flakes off, leaving a bare metal surface.
rattlecanned with the same method as I described above:
If you can get that black crap off I would but if not it can be painted over. I just cleaned it real well sprayed it with high heat primer then a high heat red. Then got a cheap sponge roller from walmart and a small jar of armor all and rolled the black on. I scratched it up when I put the motor in the car so I started to bead blast it. I will repaint it some other day. Its not hard at all just take your time. I would replace the valve cover gasket when you paint it. Don't get any paint under the cover or in the crack where the gasket goes. just lay it on a flat peace of cardboard and masking tape up the breather and oil fill hole.
This it my valve cover and I did the top of the intake to match hell I did the hole motor to match.
1 - 7 of 7 Posts
