Lots of questions, hopefully lots of answers.
693 views 7 replies 5 participants last post by  RbKouki
Been a while since i posted, had a few questions for you guys....(questions are for a 95 240/automatic). I'm a newb so bare with me.
1. While I'm driving, my car is really bumpy, especially when i'm on the freeway. I was wondering if I change the springs to lower the car, will it make it worse or better? (what can i also do to make it better)
2. When I leave my car parked for longer then about 15mins, and turn it back on...the gas pedal is sorta stuck in place and i have to kick the pedal down to get it back to normal... Is it something i should be concerned about, and if so what do you guys think it is?
3. Last but not least, after i've been driving for about 5mins or longer, and park my car, it starts making a crackling sound for about another 5mins beneath the car and on the front end. I have no idea what it is nor if its harmful. (sounds like the candy thats pops in your mouth)
Any suggestions would be greatly appreciated.
1. 240s are bumpy... its just the way they are (noisey too) probibly nothing to be concerned about if you dont mind it... aftermaket will usually make it worse, you sacrifice comfort for performance
2. the gas pedal thing ive never heard of... my clutch tends to get stuck depressed but still performs the same anyway, i usually just pull it back out with my toe and continue or drive with it stuck depressed till i get a chance to pull it back
3. thats normal tinking you hear, thats just the hot metal cooling down, probibly your heat sheild or somethin... not uncommon for that to happen :thumbsup
1. your struts are blown
2. your thottle cable is getting stuck, hurry and fix it before it scares the living shit out of you, especially since its automagic
3. ^^^
thnx guys, any other ideas would be helpful as well. I'm going to look into the struts and the throttle cable.
edit: also, any aftermarket struts that you guys reccomend? or is it all (aftermarket/oem) pretty much the same. (i hate driving newer cars that are so much smoother :\)
I wazs having the same problem with the road being bumpy, I bought smoe potenza S-03's and that went away MOSTLY, im sure as the previous posts said a good set of Shocks and that should be fixed. As far as the Gas pedal sticking mine did the same thing for a while but just stopped one day and hasnt done it since.
