KA24DE, 120-130psi on all cylinders, cold or warm. WOT, good battery. I did only have 2 spark plugs out at a time but that shouldn't effect it. The car doesn't overheat, theres no CEL, the spark plugs are healthy, the oil/coolant are good, it does not smoke, no misfires/weird idling, has power, its literally perfect. I did a wet comp test w/ a teaspoon of oil on 1 cyl and that didn't effect it. I noticed that I got 120 psi no matter if the throttle is open or not. Could this just be a faulty tester thats somehow not sealing all the way? Any other stories of very low compression but the car runs normal? Would you guys drive it until it starts showing actual symptoms? I want as many opinions as possible / explanation for this since Im stumped. If it were valves the car would be running rough, especially at 120 psi.
