i connected the park/nuetral wires together (nex to the fuse box) and i unplugged the key solenoid.. it still wont start from inside, what do i do? help me!! i dont wanna jump it from under the hood everytime!
hey man im in the same situation right now. I got everything plugged up. im gonna take a test light and see if the starter is getting any power. I think that is the best thing for me to do right now. Let me know if you got that thing to start or to crank over.
the thing to do is to get on the passenger side fuse box and and at the outside of that box at the bottom there is a two prong plug just jumper that together
sorry for such a quick non descriptive answer but when I have time I'll post the best answer I can
did that, i mean i wont get any signal from inside the car. i need to jumper it from the outside. i can crank it from those two plugs. i jus set a bridge across the two wires, and connected the plugs. it starts the car.. but i can't start it form inside. i'm jus going to set it up to a switch so i can jus push start it. any suggestions? bad idea?
I finally got it to crank. it runs alittle rough but i should be able to fix it.
I plugged it in before and it didnt work. we played around with the wires and put it back the way we had it and it worked.
I would make sure that your main ignition power is wired up right.
which connector is the park/nuetral wires? I looked all over this forum and i couldn't tell which connector is the park/nuetral wires. THis is the last step for me to finish my swap... any help in detail will be helpful.
Under the fuse box on the passenger side fenderwell there is a thick black wire with a yellow tracer....that wire needs to be jumped together because it's the nuetral safety switch. I was pulling my hair out...mine wouldn't crank either. You literally have to unbolt the fuse box and lift it up to see it.
Related Threads
Nissan 240SX Forums
posts
1.6M
members
94K
Since
2002
