1 - 4 of 4 Posts
Does the SR20DET ECU and wiring harness plug right in or will it cause any problems when installing. In other words are any adapters or other extra parts necessary to get it wired up. (FYI for a 1989 S13, Red Top SR20).
Forum Founder
If the wiring harness is from an SR car, it should plug right up to the SR ECU..Unless you are talking about your stock wiring harness pluggin up to a SR ECU...:confused:
No, the SR20DET wiring harness. I think I may have phrased the question badly tho. Basically what Im wondering is, when wiring up the SR20DET harness are there any special adapters/fittings, etc needed to get the whole thing juiced. Or does it all plug right up (with the exception of compensating for the RHD/LHD issue).
Everything plugs right up.. you have to extend a few wires here and there and move around a few wires by the fusebox, but nothing too extensive. The plug that goes to the instrument cluster does not plug up, those will have to be soldered together.
1 - 4 of 4 Posts
