1 - 7 of 7 Posts
Right guys a buddy of mine is building a ca18, i have no clue about this engiine as im a 2jz man. But this is the build list could you just have a little look through this and make suggestions if needed od modify the build in any way.
Weisco pistons +1mm
Forged Rods
Spec racing clutch
Jun Flywheel
Top Mount manifold
Tial 60mm wastegate
Full custom fuel system with -6 an lines
Arp head bolts
GT3076r or maybe a t61dbb advice needed
Cams suggestions welcome again
Apexi power fc
3.5 bar map sensor
Cam gears
B&m short shifter
Willwood 6 pot front brakes and 4 pot rears
Tein fully adjustable suspension
FMIC
Thats about it i welcome suggestions regarding turbo size and cam selection, thanks everyone in advance
Andy
Bushing replacement, although that is suspension, not engine build wise. That's just something I hear makes 240's drive smoother.
Yeah sorry forgot to mention we had already done that, and replaced the gearbox and engine mounts
Discussion Starter #6
We ended up going with a T61dbb with a .58 A/R.
as much power as he can get lol, within reason.
Andy
HKS or JUN cams. If you go with anything larger than a 264 cam, it will require shims and solid lifters. Also, it won't be a bad idea to beef up the valvetrain with springs/retainers and bronze valve guides.
1 - 7 of 7 Posts
