1 - 9 of 9 Posts
· Registered
Just curious what color wire did you guys splice into when you wanted the guages to light up when you turn on the dash lights? There is light 8 coming from the dash light/head light switch
· Registered
I would also like to know how exactly you hook up the gauges to a source that comes on when you turn on your lights. Do I just take off the steering column cover and find the black/white wire that leads to the blinker/headlight lever?
· Registered
Discussion Starter · #7 ·
I got tired of all the wiring, so just decided to combine power wire of my gauges with light bulb wire. and then I just ran the wire off my Headunit power wire, yeah the gauge lights are on all the time but you can't really tell during the day time. All I need to do now if to run the sending wire from Water temp gauge to the radaitor hose inlet, I saw this adapter piece on www.splparts.com that I might get.
How did you guys hook-up your Water temp sending unit?
1 - 9 of 9 Posts
