1 - 2 of 2 Posts
I am repairing the harness for my friends ca18det ,his harness was damaged. some one hacked off the ignitor and resisitor pack. I ordered a DSM alternative along with q45 part #22020 60U00 (green label). I have received the ignitor and both q45 plugs.my friends harness has the ignitor plugs missing.The wire colors on the q45 connectors do not match the ca18det harness. .my question is ,does some one know where to find a step by step guide to wire the two plugs from the q45 ignitor to the ca harness?
/Ive searched and found a link to heavythrottles web site ,the link is not working.
this is it http://www.srswap.com/faq/faq_ignitor.asp. this link might help ,i got the exact plugs as the ones attached to the ignitor http://datsun1200.com/uploads/photos/19144.jpg
can any one help...thanks
Discussion Starter #2
thanks for all the help..................................
ok so i found a DOC image for the same ignitor but its for sr20det install.it uses the same ignitor , the sr input wiring colors a diferent than the ca18det .the ca18 uses R/W for coil pack #1. R/Y for coil pack #2. R/G for coil pack #3. and last R/L (blue) for coil pack #4. so I just soldered my connector using the sr coil pack #designation but wired it using the ca18det pin out 1,2,3,and 11, black goes to ground
1 - 2 of 2 Posts
