1 - 5 of 5 Posts
· Registered
so here is the deal... i did a brake swap (oem) with pads... my front brakes stuck after that... like they are not disengaging all the way... so i thought that my piston was seized so i get a new caliper but it still does it... any ideas, master cylinder maybe?
please excuse my horrible spelling.
· Registered
if your calipers aren't backing off and your brackets aren't siezed, it may be the master cylinder. keep in mind there is always contact between pad and rotor, even when the brakes are not being engaged. if it's like the brakes are always on however, there's something wrong.
I'm assuming your compressed the front calipers and threaded the rears back in before your swapped pads...
if it's slight rubbing, don't worry about it. replacing the mc should be the last thing to check.
1 - 5 of 5 Posts
