1 - 3 of 3 Posts
I took off all the hoses, the bolts on the bottom and top and something is still holding this sucker on there...
There are two long bolts that are visible when you take the plenum off. They bolt to the head on the underside of the intake ports, BUT the bolts actually through the intake manifold all the way and exit on the top of the runners. I couldn't find those for a while until I actually took the plenum off.
If you don't have an FSM, get one. There is a diagram that shows what I'm talking about.
Did you remove the intake manifold bracket? Its held on by two bolts on the manifold (under the manifold, its looks like a Y kinda), and 1 bolt (14mm hard to see) is bolted to the block.
1 - 3 of 3 Posts
