Status
Not open for further replies.
Need Help with JDM S14 Door Sills
4.4K views 27 replies 19 participants last post by  BoostinIX
Anybody install these? The "silvia" logo is supposed to light up when I open the doors.
Each sill has 2 wires comming out of the indiglo strip. I'm sure you hook these up to the blue wires comming out of the transformer. Then I guess the red and black wires on the transformer are positive and negative and would simply plug into a power sorce. I'm just wondering if anybody has ever installed these in their S14. All the help I can get will be great! :)
**Also, my sills came with just one transformer. Shouldn't there be 2 of them?(1 for each sill)?
TIA,
Lui
Shaminii, you dont want to know how much I paid for these. :tears ahahha.
I figured out how to wire everything up now. I just would need to find the leads for the domelight or even mabey the leads that trigger the alarm when the doors open. :12dunno
I went ahead and hooked one of them up to a 12v power supply just to see if they worked. Below are the pics:
Few questions about them.
Do the door sills for the driverside and passenger side both illumiate? I'm asuming they do. Is this a Japanese aftermarket item or did it come stock in Japan?
#12 · (Edited)
RB25DeT//240sx, I paid $150 for them. Yes, a bit on the expensive side, but I'm a jdm whore! :dancingco
NiteKids, both the driver and passenger side light up when the door opens. I know they are JDM OEM Nissan, but not sure if they were a factory option from Nissan or if they came standard with the S14 Silvia.
NiteKids said:
JDM Or Whatever who gives a shit. those are pimp
Well to be honest, when I found out they had the indiglo strips, I thought that was kinda ricey. Now that I have seen them first hand, I love em! :yummy
ok here is what i'm thinking
you will have to run some wires!!!
1)red = pos+
2)black = negative-
3)each one of these blue wires go the one of the wires on the sil it self
4)the one of the wires from that sill wil go to that sensor and tap into the wires
so when ever the door is opened the curent can go through and light up the sills
just my 2 cents
1)red = pos+
2)black = negative-
just my 2 cents
Yeah, I was thinking the same. All i would have to do is locate the hot/positive wire going to the dome light.
Shaminii said:
where did u buy them??
I was lucky enough to find them on Ebay of all places! :D
Both sills will light up (passenger and driver side) and this was a nissan factory option item in Japan.
S14.5
http://www.H2Fparts.com (coming soon)
Hopeing you can help I just got my door stills but it came with jdm oem green floor lights x2 and the light up key ring and a lot of uncut harness my ? Is did you need to cut any thing my harness came with alot of stuff that I don't think would work in a usdm 240 it just looks differnt any help would be grate thanks
double fuckin' bump on a 7 year old thread. It's good you know how to search, but look at the dates before post. :fonix:
Status
