I bought and recieved a block that turned out to be damaged:
Here is an over view of the carnage.
So yeah... the #2 rod and cap bit the dust as well as the crank. I'm about to clean the block out thuroughly to see if the piston walls are damaged. If not and the journals look good I do have another crankshaft I can use. My question is, the pistons took a little abuse and got some scaring on the skirts both intake and exhaust side. the #2 piston took a bit more trauma with the scaring. Based on this picture does it look like I can reuse the piston if only for a stock rebuild?
Thanks
(#2 piston is on the right side.)
Thanks
