tallic_red240sx said:
I wanna do this, but I have nobody to help me bleed the system once I get everything removed.
I bleed all my brakes/clutches by myself and have never introduced air into the system. All you need is a some clear tubing (preferrably silicone) to hook up to the bleed screw.
Just make sure that immediately where the tubing connects to the bleed screw, the tubing is higher than the bleed screw for at least 6 inches of tubing. The more tubing you can raise above the bleed screw, the better.
When you press the clutch/brakes, make sure you hold it at the bottom for a short while to allow any air bubbles to go to the top of the fluid in the tubing, then pump again. You'll have to check periodically to make sure your container doesn't overflow and that your master cylinder doesn't run low on fluid.
Also, I performed this mod but didn't notice any difference whatsoever either. I guess it will make future clutch fluid bleeding faster, but clutch fluid shouldn't need to be changed often.
