1 - 20 of 42 Posts
Automotive Lighting Experts
Nissan 240SX License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your 240SX. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your 240SX!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your 240SX looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your 240SX).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
194 Bulb Model Options
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
1 - 20 of 42 Posts
