1 - 20 of 49 Posts
Automotive Lighting Experts
Nissan 240SX LED Turn Signals
Switchbacks will require basic socket and wiring modification. Please call: (314) 205-3033 for more information
Click to order or for more information:
240SX Turn Signal LEDs Front Turn Signal LEDs
240SX Turn Signal LEDs Rear Turn Signal LEDs
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
HP11 Amber:
XP80 Amber:
Switchbacks with Turn Signal Activated:
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, email
[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
***MORE PICTURES COMING***
Thanks for looking!
Nick C.
Diode Dynamics
Premium Member
Those SMD27's look FCKN AWESOME!
Too bad I don't have a 14 anymore :(
Do the SMD27's come in Switchbacks?
Edit: I see they come in SMD60's, do you have any pics of those?
Edit2: Also would like to see this same comparison with the Tailight bulbs how the SMD27, HP11 & XP80 compare in Color and Brightness.
Discussion Starter · #9 ·
Hey Nick, was wondering it you had à chance to shoot and try out the different variations.
Looking to pick up a few and review.
We haven't had time to shoot the tail light comparison shots yet, but I've tested fitted everything in my S14 to confirm it fits and works perfectly.
I have the XP80's in my tail lights and the HP's in my reverse lights
Nick C.
1 - 20 of 49 Posts
