Can anyone tell me Nissan's recommended oil grade for the KA24DE (s13)? Thanks.
Have you pulled the cams out of a Ka24de? That "bucket" is a hydraulic lifter. Its not a solid follower that use shims to set the lash. The follower expands with oil pressure to take up the lash, hence the term hydraulic.ghostchild316 said:SRs actually have rocker arms.KA24DE is direct cam on bucket.I dont see what's so "hydraulic" about the valvetrain.On the KA24E it's pretty obvious
sorry to bring back the dead...but the de is a shim in bucket style valve train. there is nothing hydraulic that I can see about it. It goes something like this1Bad240SX said:Have you pulled the cams out of a Ka24de? That "bucket" is a hydraulic lifter. Its not a solid follower that use shims to set the lash. The follower expands with oil pressure to take up the lash, hence the term hydraulic.
Oh yeah, and back on topic, I use 15w50 Mobil1 exclusively.
2ndmoto said:sorry to bring back the dead...but the de is a shim in bucket style valve train. there is nothing hydraulic that I can see about it. It goes something like this
cam lobe
shim
bucket
retainer
spring
valve
the shim is what takes up lash, use different shims to add or take away tolerance. You can buy different thickness shims from nissan.
If you pull the cams out, and you pull the bucket out, and then pull the shim off the top of the bucket...there isnt any oil passages. I cant see how this is hydraulically adjusted.
What I am missing about this? please someone fill me in
2ndmoto said:thank you Kenny. I knew I wasnt crazy. The voices in my head told me so!!
