1 - 14 of 14 Posts
Suck My Balls!
well when i bought my car the odometer and speedometer did not work sometimes they would flicker on and read wrong numbers. the way i fixed it was by swapping out clusters so i still cant point the EXACT cause.
Jimmy
From what i've heard is they tend to go out after so many years, Mine did, they are mechenical, I just got junck yard replacements that worked fine forme, got them for 10 bucks I think.
240SX Padawan Learner
Discussion Starter · #4 ·
I can't remember what it looked like when I took my cluster out but I'm guessing that the odometer and trip odometer are single units like the clock, tach and so on and that I don't have to replace the entire cluster correct?
Suck My Balls!
correct. the tachs are not interchangeable between the (KA-E or CA) or (KA-DE or SR) though
the odometer and tripometer relys on the speed-guage and vehicle speed sensor, check the circuit or check the sensor or speed guage for functionality. i put in a digital cluster and the digital speedo didn't work along with the odometer and tripometer. i replaced the digital speed with a working one and both the odometer and tripometer works fine.
My speedo hardly works too!!! I have to bang on the sensor before just to have it go on and off when in drivin
the vehicle speed sensor is at the rear most of the tranny. guage cluster, is well in the instrument cluster.
Discussion Starter · #11 ·
WTF!!!??? I get in the car tonight and both the odometer and the trip odometer are working just fine. I hate it when something works and then doesn't and then works again...me personally, I like closure. It either shouldn't work at all so I know that I need to fix/replace it or it should work normally so I know that I don't need to worry.
i just bought a 92 240sx with a redtop sr20 and the all the gauges work except for the speedometer, i changed the speed sensor with one provided but the guy i bought i off, so after installed it still no speedometer...so what i am hearing from you guys is that it is mostly likely the gauge cluster and not something else? and if so what might it be?
my clock is acting all funny too. any sugs?
my clock just went out, too! Mechanic changed the passenger door switch and it works again!! Unfortunately, I also changed the speed sensor, and my odometer, tripometer and cruise STILL don't work. UGH! anything?
1 - 14 of 14 Posts
