Well been doing a little bit of Researching and Reading and Got interested into OEM Sway bar swaps after seeing that ALL S13 & S14 Rear Sway bars are interchangeable. I wanted to know if the Front were interchangeable Between the S13 and the S14???
These are some specs I got
S13:
Convertable & Base:
Front - 24mm Orange(Color Indication)
Rear - 15mm LightGreen
SE:
Front - 25mm White
Rear - w/o ABS/VLSD - 17mm
Rear - w/ ABS/VLSD - 21mm Red
S14:
Front - 27.2mm LightGreen
Rear - 15.9mm (SE Only) Blue
I seen a few S14 guys d the 27.2mm / 21mm S13 Rear Sway swap
If any S14 Guys are running the 27.2mm / 21mm Sway set-up how has it improved your handling?
Update:
J30 Rear Sway Bar: Direct Bolt-on (Per Def)
19mm Hollow - ~1.5lbs Lighter than S13 15mm
S13:
Convertable & Base:
SE:
Front - 25mm White
S14:
Update:
