Here its goes. I have been driving my 96 240sx for about a month now. I have had a overheating issue primarily because the cooling fan on there was too small. Changed the fan to the correct size and eventually a few days later problems persist.
Next I change the radiator hose because the other hose sprung a leak. Later that week the issue is still prominent. I continue to drive the vehicle leaving the fan on and it stays at a medium temp and continues to do so. I continue driving for maybe a week or two and the other day my car gets really hot for no apparent reason. I look under the hood and the coolant is backing up in the reservoir tank and its boiling :gaah:!!! Then on the way back home the car begins to smoke and i pull over in the turning lane and open the hood and there is liquid everywhere and I see that it splashed under the car as well hitting the exhaust and that is why it was smoking. I check in the bay again around the radiator and the small hose on the bottom right side [if you are facing the car] has ruptured.
The car still turns on but it won't go into gear. I was wondering if that hose has anything to do with the trans?! If there is anyone out there that can help me with this I would love the feedback. Thanks!
:feedback:
