overheating problem
4.7K views 99 replies 30 participants last post by  TREV0R
So my car is overheating and i have no idea why. Its a ka24de. I just fixed the headgasket about 4 months ago, and before that it got a new thermostat, a new radiator, and a new oil pan gasket. ive checked everything i can think of, its full of oil, its got water in the radiator, but it keeps over heating. Its werid, i can start it, let it warm up, and its fine, and then i drive it and its fine, then after about 10-20 min of driving it starts to over heat, and then it was pissing me off, so i started to beat on it, and it cooled down, and today when i pulled into my driveway, the check engine light came on, and i pushed the clutch in, and it died, can anyone help me, maybe its the thermostat, even though its got a new one, or a sensor? thanks to anyone that helps
its probably air in your cooling system
you need to get the front up on ramps
take off radiator cap
have coolent/water mixture ready
turn it on then let it warm up(to open thermastat)
squeeze all accesable hoses let it overflow and it will bubble keep doing this untill bubbles are gone keep adding coolent mixture to keep the level high
my friend and i did this and it solved our problems
i did a compression test and i got 170, 180, 165, 165, so im good on that, my step dad thinks its the water pump and so does my friend, so im gonna try that first, as soon as i get enough money
#11 · (Edited)
i just put a new water pump on, a new water temp sensor, and a new water temp switch, and it still over heats, i guess tomorrow, im gonna go buy a new thremostat, and some seafoam, and see if that fixes it, any ideas on what else it could be?
i already did, but yeah i bought a new thermo and some radiator flush shit, so ill do that tonight
to properly bleed the system u need to run the car(with coolant in of course) with the heater on(ac off) full blast. wait til it reaches operating temp. keep refilling as necesary, all air bubbles should come shooting out. takes about 20 min. THERE IS a chance that air is getting trapped between the coolant and thermostat causing it not to open, which would make ur car overheat. signs of this is the thermostat not opening and the coolant will boil out of ur radiator filler while ur doing this.
how did the flush go
i think your intake manifold should have a water jacket bleeder ... its just a 10mm bolt on the manifold and lets air out of the highest point of the cooling system.
also check for belt tension and make sure your tensioner bolt isnt sliding when youre driving.
those were the things i had to look at when i was having cooling problems... did those things and flushed and my car hasnt gone over half since...
go to a shop that will change coolent with this machine that makes sure no bubbles are in it when i took out my thermo there was this gross brain lookin shit in it after i cleaned that and replaced and changed water pump and coolent i was fine
im about to take it to a shop after after i flush the radiator, which im doing tomorrow, and i put the new thermo in, so tomorrow night ill have a update, and thanks for the replys guys
ok i flushed it, and put a new thremo in, and i guess the gasket is bad because it leaked bad when i tried to drive it around, and its really cold, so ill fix that tomorrow, this is what i cleaned outta my radiator today
and this is this morning
my car stuck in my yard, damn rain
#25 · (Edited)
okay...i fixed it so its not leaking now, but it still overheats, i have no idea what it could be, i bled the system perfectly, ive changed everything possible i think. i dont know what to do, and ive noticed when it starts to overheat, it only does that when i have it in gear and am giving it gas, if i pop it into neutral and coast the gauge will stop going up and either stop there, or go back down
sounds like it could be a wiring issue. Is it actually overheating or are you only going by the gauge in the car? I know you said you replaced the temp sensor and all, but i would double check all of the wires and make sure none are shorting out or have come loose, because if it is perfectly bled you should have no problems whatsoever and you have a 170 thermostat so you are plenty good to stay cool, im starting to beleive you may have a wiring issue so check all of the wiring that goes to the coolant temp sensor, that is the only reason your car died when you pushed in the clutch in the first place is because it was not reading correctly and told the ecu to give the wrong parameters and either starved it of fuel or gave it too much, plus your check engine light came on so double check those connections just to be safe!
Ok so everyone is going after everything in the cooling systme except the fan. What are you runnng? stock or electric? Does the temp come back down as your cruising at highway speeds then creep up as soon as you stop? If your running a stock fan, it looks like the fan clutch is gone. go to a junkyard and get a new fan clutch, you could transfer your actual fan to the new fan clutch. make sure your runnin a shroud! If its an electric fan, make sure it has a shroud, and make sure its switches on when its supposed to
#29 ·
i have a stock fan, and when it starts to overheat, after about 10 min of driving, if i put it in neutral, it stops, then if i put it in gear and accelerate it starts to go back up, thats whats been happening now, and i was thinking about getting a temp gauge and hooking that up to see if it actually is overheating, thats the first thing i thot when i read orange silvia's post, but ill go get a fan clutch, can i use one off a sohc?
