1 - 2 of 2 Posts
So my Electronic Ignition Module or Transistor Module is out. I have been trying to connect a hei from a gm with no luck. For some reason I'm not getting a signal from the pickup coils, I have 2 in the distributor. A new pickup coil doesn't exist for my federal emissions setup. and a new distributor is several hundred dollars or more and hard to find. Can I order a Petronix ignition switch in the distributor? Does it mount there instead of one of the pickup coils? If this works, I won't need the transistor device anymore and can wire the power from the Petronix directly to the coil. Just wondering if this is a possibility?
1 - 2 of 2 Posts
