:idea: You must check your hoses to the trans and if they have no blockage most likely the trans is bad. try a transmission screen cleaning before swapping out.
:idea: You must check your hoses to the trans and if they have no blockage most likely the trans is bad. try a transmission screen cleaning before swapping out.Hi, I have a 1995, 240 sx Nissan (automatic) but my transmission has not been working correctly, well thats what i think.. because my dad and i changed the previous transmission because we thought it wasnt shifting correctly (when it would change gear, it would take it a really long time, and i had to floor the gas until it finally gave in and shifted). But now that we switched the transmission, it still does the same thing... so does anyone know what might be the problem? This would really help me if anyone could identify a problem for me... thank you.
