1 - 4 of 4 Posts
Ok im planning on doing an sr20det swap in a 92 5 spd fast back im getting. So far i've researched the swap process and what i need to install it just want to double check. The swap will come complete with everything needed to install and start up. But what is recommended to change before installing the motor? in ex oil pump, water pump, gaskets, sparkplugs. What is nescessary? All help appreciated.
240SX Padawan Learner
Swap out as many gaskets as you can because most of them are pretty cheap and it's the perfect time to do it while you have the engine out. Clean and paint the engine, makes it much easier to spot any leaks you may have after startup.
waterpump waterpump waterpump. Do NOT wait on this one. Just drop the 80 bucks on it and forget about it. I didn't get four blocks on mine before it took a shit. I also did plugs o2 sensor and most of the gaskets. Oh, also did the cts also. Good luck.
1 - 4 of 4 Posts
