There are a few ways to remove hydraulic handbrake in s14:
1.Use a wrench to unscrew the bolts that hold the handbrake in place.
2. Pry the handbrake cable off of the caliper.
3. Unscrew the bleed screw on the caliper and release the pressure in the system.
4. Pull the caliper off of the pads and remove the pads from their housing.
5. Remove the piston from the caliper body using a C-clamp or other similar tool.
6. Pull out the rubber FKM seal from inside the piston and dispose of it properly.
7. Insert a new seal into the piston,
