You can run 10psi on stock compression. Which is 9.5:1 for KA24DE. Just make sure you have enough fuel.
Edit.. and yes, lower compression allows more boost on pump gas. higher compression you get more hp either way you go, NA or forced induction.
it's just that lowering compression is ideal for turbo and you do lose some power but it's made up, up top with the extra boost you can run.
