I was mulling over this. The benefits, dis-advantages, and why the hell does the rb20det intake manifolds cost way more than the rb25's??
discuss??:WTF:
discuss??:WTF:
I think the factory setup for an RB20DET is reasonable, since the car uses a SMIC and the piping going over the engine probably decreases the distance between the cold side of your SMIC resulting in quicker spool for the little fella.
One of the first things to go on many RB turbo upgrades is the SMIC in favor of a FMIC. When retaining the factory intake, you typically end up with a strange "around the world" setup. I also personally think that the extra heat from sitting on top of the engine doesn't help with the air you've just cooled through the FMIC, but I don't know enough about the physics of heat soak in situations like this to confirm that theory.
Now, when going for a forward facing / intake plenum you get better piping logistics for your FMIC, the potential of running a larger TB for higher air-flow scenarios, and if it's built right it should more evenly disperse the larger amounts of air into each cylinder.
I hope that's what you were asking.
I'm not sure about pricing on your last question. Do you mean RB20DET vs. RB20DE?
