1 - 4 of 4 Posts
hi guys. i finally secured a 91-93 240sx powersteering setup.($89.00) and i have a question now.
on my power steering pump i have 3 spouts(2 on top one on bottom) i was guessing the bottom one i didn't need so i plugged it up. my question is does anyone know which one is the low pressure line and the high pressure line??
http://i495.photobucket.com/albums/rr317/supersayianjim/misc/powersteerpump1.jpg
http://i495.photobucket.com/albums/rr317/supersayianjim/misc/powersteerpump2.jpg
http://i495.photobucket.com/albums/rr317/supersayianjim/misc/powersteerpump3.jpg
also i was going to ask carl if he could wire this fan to work on my radiator??
http://i495.photobucket.com/albums/rr317/supersayianjim/misc/confan1.jpg
http://i495.photobucket.com/albums/rr317/supersayianjim/misc/fanwire2.jpg
the lower one goes to your oil reservoir, use the first spout for you powersteering (the one closest to the pulley), im pretty positive the back spout is for HICAS. theres also a write up on that how to eliminate it,
do you have a link to that writeup?? also is the one at the back the low pressure hose??(cause powersteering has 2 hoses)
The one on the bottom/side goes to the reservoir. The one at the top by the pulley is used for ur front power steering rack. You will need to block off the back hicas line. You will also want to take off the back cover (opposite the pulley) and remove all the little metal pieces in the pump wheel with a magnet.
1 - 4 of 4 Posts
