1 - 5 of 5 Posts
hey does anyone have a diagram with torgue specs and patterns for the rb20det. i would like to change the rear main seal(not leaking just for future insurance). and i need the exact bolt pattern for that. also i have a slight ding in the oil pan. and worst case is i have to remove it to bang it out.
-diagram and torque specs for the clutch and flywheel
-torqus specs for the oil pan
-and a diagram on how to remove the timing belt.
i would like to change the water pump. and doing that without removing the belt looks impossible. any help would greatly be appreciated thank you.
download the FSM and you will find all the info you are looking for. heres a link (dont know if it still works)
http://www.random240.com/240/r32all.pdf (right click it and save it)
you should also change your timing belt, idler and tensioner when you change out your waterpump. i dont know if you found parts already but i like it get oem rb stuff from nismoparts.com.
hope that helps
HEY ANV1L THANK you so so much for that link. downloaded the whole manual and iam trying to print up all the pages.
thanks man
np man... just trying to help whenever i can. thats a lot of printing to do if you plan on printing the whole thing! lol i just have mine saved on a thumb drive and just look up stuff as i need it and print out pages as i need it
1 - 5 of 5 Posts
