English please
Yeah, sorry man that's really hard to read. It doesn't take that much more effort to type "and" instead of n and "what" instead of "wat". This ain't the streets son.English please
It's been a while, but I'd say MAF, CAS, igniter chip (if S1), ECU and uncut harness. Watch to make sure you get a real RB25 tranny. I've heard of shady importers swapping them out for the RB20 tranny.Okay, so I'm thinking about getting an RB25DET clip and had a few questions before I buy it.
First, what little things should I make sure come with it so I won't be screwed later on? (Like the MAF and stuff.) I'd like to make sure the only things I'll have to buy are the driveshaft, mounts, and fuel pump. Also, I've been looking around for clips, but I wanted to know if anyone knew of a good place to get them from (somewhere that's not too expensive).
If want to use the dash from the clip, will I have what I'll need to convert the steering? If not, what else will I need?
Ok, so I'm about to buy a rb25det clip and had a couple of questions before I do. First, what little things should I make sure come with the clip? For example, the maf and everything else so the only thing I'll really have to buy is the driveshaft, motor mounts, and fuel pump. Also, I've been looking around but was wondering if anyone knows a good place to buy a front clip that isn't too expensive. If I want to use the dash from the front clip, what will I need to convert?Ok so on fixin 2 get myself a rb25det clip n had a few questions b4 I buy it. first is wat little things must I make sure come wit it so I won't b lyk Vergas later on.. lyk da maf n stuff , so dat really da only thing ill have 2 buy would b just da driveshaft n mounts n fuel pump. Also I've been lookin around but was wanting 2 know if any1 of ya know a good place to buy da clips at Dats not too expensive. N last question if I want to use da dash from da clip will I have wat ill need to convert da steering if not, wat will I need.
:feedback:
