He guys,
I'm really in a bind right now. Im doing an auto to manual swap and I've hit a wall.. I removed the shaft and all of the bell housing bolts but the transmission wont slide off. Now i thought that i might have to remove the torque converter to slide it off but when i tried to turn the crank pully the whole transmission turned. So i bolted up two bolts on the bell housing again and the crank wont turn. Now i know the engine is fine cause i used to go to the garage to run the engine once a month. Now could the tranny have siezed up and if so how would i go about removing it? Some say it should just slide off with some wiggling and effort. I really need help from those who are experienced with the auto tranny asap.. HELP =(
