I started to think today on how to help against the turbo lag of a larger turbo such as a 2871R .86 or larger. I remembered the different rear gears that are available for the car. Since our stock rear is 4.08 and if we make the rear a 4.36 or 4.63 then that should help with the turbo lag since the rpm will be higher in each gear than stock and the engine would go faster through each gear. Would this concept work or not?
4.08 rear gives 174mph @ 7500rpm (5th gear)
4.36 rear gives 163mph @ 7500rpm (5th gear)
4.64 rear gives 154mph @ 7500rpm (5th gear)
http://www.f-body.org/gears/
Chart For Tranny Gears
