Drop the steering column, 2 14mm bolts above the pedals and 2 14mm bolts directly under the start of the dash, should be a polished bronze color(mine were anyway). After you drop the column, you can pull down one corner at a time on the shroud. Little by little it will budge, gradually bending itself in the middle, 1/2 an inch of bending is probably the limit. If you cant get it out then get a flathead screwdriver and pry down on the top, between the dash and the edge of the shroud. Pry down about 1/8 of an inch on each side every time, switching back and forth. Make sure the two clips on the bottom are undone of course. After you get the entire edge of the shroud visible on the top pull on the bottom edges till it comes loose. If you need any more help on it or the cluster PM me.
