rubber peice between tranny and driveshaft??
2K views 11 replies 7 participants last post by  Dark-Hawk
when i pulled the engine out of my car i noticed that the drive shaft mounts to a rubber spacer type thing that mounts to the tranny. and i was wondering if u could just bypass this rubber mount with a metal spacer.
im thinkin that if u do this u can get rid of play that would be in this worn out peice of rubber. and in return u might be able to feel a little more throttle response.
but the only negative thing i can think of is. that if u mount it solid. it could possibly tear up any of the other drive train peices.
wat do yall think about this? do u think it would tear anything up?
i wouldnt mess with the driveshaft, if it gets unbalanced you will have problems
