s13, ka-t, 35k.
156 Views 0 Replies 1 Participant Last post by  Venom369
$3,400 FIRM, as of now. If the deal I'm involved in falls through, price is going back up to 4,000. Theres $3700 in parts alone not including the price of the 240. JUMP ON THIS. Trust me!
-1990 240sx
-Turbo boosting 7psi on rebuilt ka24e engine (35k)/ Transmission has about 80k on it.
-Have another stock actuator thats set to run at 10psi.
-Safc2 for tuning. Easy to use
-Comes with the black rims in the picture, also the stock set with 85% tread on the tires, AND another set of rims with BRAND NEW snow tires!
-Audio is good. Decent aftermarket speakers all around, no subs. I would upgrade the deck though.
-Ac delete.
- The heat blows hot.
- One very small dent in the very front of the passenger side of the car.
Only things the car needs is an alignment. Thats it.
-Engine/Tuning:
KA24E-T 2.4L with 35k miles*
Slight port on head and intake
Rb20 turbo (250 miles)*
Thick wall 304 stainless turbo manifold
Rb20 downpipe with a high performance pacesetter exhaust and a gutted high flow cat.* (Car is as quiet at stock though) No loud civic sounding exhaust here.
400cc rx7 injectors*
24x9x2.5in front mount inter cooler
2.5in hot and cold pipes
Greddy knock off blow off valve
ECU Eprom tune in computer*
Apex SAFC2 for fine tuning*
PLX M-300 wideband*
Auto meter vac/boost gauge
Auto meter oil pressure gauge
-Suspension/Driveline:
Tokicko HP blue shocks*
Tein S-tech springs*
Suspension techniques front and rear sway bars
RSR tension rod bushings
Aluminum sub frame spacers
J30 Vlsd limited slip rear differential*
Shaftmasters lightweight aluminum drive shaft*
Peak performance trans bushing
JGS tools urethane motor mounts*
6 puck stage 3 pro clutch*
Fidanza 11lb flywheel*
B&m short throw shifter*
Various stock parts that have been replaced:
Entire distributor
Steering rack
Alternator
New Battery, (Mid July)
Comes with a lot of extra parts. Two starters, a spare turbo manifold, , passenger side auto to manual seat belt conversion, a couple spare ecu's, A large spoiler (not my taste) and more.
Interior is VERY clean*
Any other questions please
Call/Text: (845) 594-5401
or
Email: [email protected]
Names Mike
Thanks.
Click for pics! ----> Pictures by stealth369 - Photobucket
1 - 1 of 1 Posts
1 - 1 of 1 Posts
