More Info
Here's what I've found out so far. I've included some questions in the pictures.
All the harness diagrams are drawn from a rear-view aspect. So, you're looking at the back of the harness where the wires come out.
Wow "Finder" I'm special...........^
The S13 has a group of fender harnesses that attach to various things. Th S14 does not have the external coil so this fender harness is not used/necessary. The S13 has a Coil and power transistor mounted to the fender. Both have a harness and there is one more connector that comes out of the bundle of wires that conects to a spade connector on the coils' base... presumably to ground.
Also, the S14 Distributor has a "condenser" mounted to it with a spade connector conecting it to the body of the distributor. Do I need to move it somewhere else?
Here is the guide I found that shows how to put a S13 Distributor into a S14.
I'm trying to do the opposite so It's hard to translate it.
http://jimwolftechnology.com/wolfpdf/DISTRIBUTOR%20SR%20KA%20CHANGE%20CAR%20TO%20EXT%20COIL%20AND%20TRANSISTER.PDF
