What exactly are you wanting the swap to provide you? I see the only thing you bring up is weight. I would think that a SR20DE would be an easier swap and it would also cut down on some weight over the front end. However, it wouldn't take off as much weight as the 13b would. According to the "The LS1 is heavy" thread the KA24DE weighs in at 330 lbs. The 13b, according to Wikipedia, comes in at 247 lbs. This means a roughly 83 lb drop in weight on the front end. According to Motortrend the 240 weighs in at around 2,760 with a weight distribution of 54% - 46% (F-B). According to your numbers and if you were do the swap your weight would roughly be 2677 lbs and the distribution would be roughly 52.6% - 47.4% (F-B).
