More parts FS, DM On here or instagram (
@Cleantune) for best price shipped
Lemme know if you want pics of anything specific
Engine:
• KA24de Block + extras (silver color powder coated covers, brackets, etc; *pickup or ship at buyers exp)
• KA24de Head (not sure what’s in there, but was built by engine shop w/ aftermarket cams, so may have some “goodies”, will include cams that were in there, but highly recommend switching these out as they do not seem to match and at least one (if not both) are BC, which used to be labeled “intake” or “exhaust”, but needed to be switched when putting them into the inline version KA that was in S-chassis (*pickup, or ship at buyers expense)
• S14 intake manifold assembly w/ 555cc side feed injectors
• S14 KA24de blue powder coated valve cover w/ aftermarket aluminum oil cap
Drivetrain:
• S14 KA24de transmission + new uninstalled seals (*no shifter; pickup or ship at buyers expense)
• Competition Clutch “Whiter Bunny” complete clutch assembly machine shop balanced
• S14 clutch cylinder + bleeder assembly
• S14 axles (anti-corrosion black painted)
• S14 open differential w/ KAAZ Super Q 2-way diff w/ Poly bushings (only used for 3 driving events)
• S14 VLSD complete differential (*Pickup or willing to ship at buyers expense)
• S14 open differential (center gear section only; what clutch-type replaces)
• S14 non-abs OEM Driveshaft (*pickup; unless I can find a box)
Turbo and support parts:
• Precision .60 A/R inlet/ .63 A/R outlet journal bearing (*needs rebuild; includes bolt on oil drain tube)
• S14 Tanabe Concept G Blue Exhaust + midpipe and piping from cat back; cat/test pipe not included
(video link:
; mean deep tone; please pickup, ship at buyers exp)
• K+N/AEM dry cone filter w/ aluminum pipe and 45 degree coupler
• S14 KOYO Radiator w/ Dual Flex-a-lite electric fans (includes other side of pigtail)
• GReddy Front Mount Air-to-air intercooler (90 degree input/output-makes it easier to mount inverted)
• Front Mount intercooler piping w/ couplers (aluminum)
• Front Mount intercooler piping w/ couplers (steel)
• Apexi turbo timer (black color housing) + HKS S14 adapter harness
• AEM wideband gauge + sensor
• AEM standalone ECU + MAP sensor + AIT sensor
• S14 KA24de chassis wire harness + fuse boxes
• KA24de powersteering pump and reservoir; includes new seal kit
Brakes and Suspension:
• S14 Front and rear (full set) 5-lug non-abs brake rotors (
NEW)
• (New) Brembo S13/S14 4 lug front brake rotors
• S14 OEM brake calipers (full set)
• Stoptech slotted rear rotors 4 lug
• (2) S14 Brake Master Cylinder
• rear S14 Stoptech stainless steel braided lines
• GKTECH Euro stainless steel braided lines
• S14 GKTECH extended (+25mm) Front Lower Control Arms
• S14 Cusco adjustable toe rods
• S14 Cusco front sway bar
• S14 rear knuckles (painted black w/ red Energy Suspension poly bushings)
• S14 front knuckles
• S14 front lower control arms
• S14 tension rods
S14 Exterior:
• S14 OEM metal hood green color (*pickup or ship at buyers expense
• S14 OEM hood release
• S14 OEM Front Bumper w/ turn signals + side markers
• S14 2F Performance Fiberglass Front Bumper (
Shipping damage on corner)
• S14 OEM windshield washer tank
S14 interior:
• S14 rear seat belts (pair)
• S14 front seats (pair)
• S14 interior trim (A pillar, B pillar, Rear quarter, behind rear seat)
• s14 glovebox door
• S14 head liner
• S14 complete glass sunroof assembly w/ motor and cabin controls
• S14 OEM Steering wheel (*can only ship wheel itself, but willing to do pickup for the center section)
• S14 passenger airbag (
pickup only)
• S14 center console (black color, center door stays closed, but could use spring for latch)
• S14 interior sun visors
Universal items:
• Autometer manual boost gauge
• Walbro 255 LPH in-tank fuel pump w/ pigtail (swaps with OEM pump, enough for boost)
• WeaponR coolant round aluminum coolant overflow/reservoir tank
• PBM aluminum swirl-pot/coolant breather w/ radiator hose adapter for Nissan chassis
• Pioneer radio head unit (teal/black display w/ animations; CD player; XM-Ready
• Moroso crankcase EVAC system
• PBM Fender roller
Wheels:
• WORK VS-XX Chrome faces 3-piece 4x114.3-lug wheels (S13/S14)
• WORK Rezax Chrome faces 3-piece 5x114.3-lug wheels w/ extra lips (S13/S14)
*unless noted w/ “ship at buyers expense” price given will be shipped w/ all fees included in given price.
_
