1 - 3 of 3 Posts
Moderator
If you’ve been holding off on replacing your wiper blades, wait no longer. The popular Bosch ICON replacement wiper blade is currently on sale at Amazon for $15.77, which is a 44% savings from its normal price of $27.99.
Shop The Bosch Wiper Blade Deal Here
The Bosch ICON features a patented beam design with a shielded connector, helping optimize visibility even under extreme weather conditions. The replacement wiper uses exclusive FX rubber technology and claims to last up to 40% longer than other premium blades. A weather-shield double locking connector makes it extremely easy to install. Bosch also outfits the ICON with an exclusive asymmetrical flexible spoiler design, which distributes uniform downward force across the blade so it stays firmly put on the windshield at higher speeds.
No matter the climate conditions, the ICON will deliver a clean wipe thanks to a bracketless design and tension springs which keep the blade flexible.
Over time, the rubber included in the construction wears out, cracking and losing elasticity. In this case, the work of the wipers will no longer be as effective, which means they will have to be turned on more often, which will lead to scratches on the windshield of the car. Replacement of brushes is a straightforward procedure. You can carry it out in the car service, but if you want to save money, perform it with Recommended Sizes of Wiper Blades for Windshield and Rear Window. Replacing the rubbers on the wiper blades will not take much time. They can handle this task without any problems, as I have recently changed and everything works fine.
1 - 3 of 3 Posts
