1 - 4 of 4 Posts
So, I cut the brown wire to try and get the sleepy eye look. Nothing happened, the "mod" did not work for me. Have any of you guys experienced this? Are their any other ways to do this? I really wish that it was that simple.
Are you sure you are doing it right?
Turn the headlights on and press the headlight button.
Turn the lights completely off.
Tap the headlight button really fast a couple times to get the desired height.
If you turn the headlights on they will drop down then come back up to the full position, but you can turn the parking lights on with the sleepys.
Yeah, It will stop the headlight when pressed. As soon as the buttons let go the headlight closes. I've seen the video of the light "tapped" into place. I can tap them to a desired height but it always closes when the button is decompressed?
That's how it should work. When you tap the light button your decompressing it (dropping them) and pushing it back in (stopping the lights from dropping) to get the lights at a lower position.
1 - 4 of 4 Posts
