1 - 20 of 28 Posts
there used to be a guy in Glendale CA that did them for cheap. anyone else still doin this in the LA/Pomona area.
Discussion Starter · #5 ·
i really dont want to do it. anyone close to Pomona are that wants some cash.
dont cut the brown wire because if you do that when u turn on the headlights it will just go back to normal...u just have to put 2 switches on the relay...go on youtube and type in sleepy eye mod and they will show u which terminal to attach em to. im going to try and find the link for u
You want your headlights to be pointed straight at the ground when they are on? :scratch:
thats what sleepy eye mods are...they are only open halfway to make the sleepy eye effect...but if you want to keep it like that and have good vision at night then replace the stock headlights with projectors or you cant mount fog lights in there....depends on what you want if for..if its for just temporary looks or if u want it permanent wit working headlights...
Heres how t do it.
1. Open hood and adjust the light height to were you want it.
2. Take out the headlight motor fuse or relay out.
3. When you want them to go back to normal put the fuse or relay back in
another way to do it is if you cut the brown wire and then adjust accordingly and then pull out the fuse for the light control under the dash by the dead pedal you can turn the lights on too. and then u can put the fuse back in when ever you want to use the headlights.
1 - 20 of 28 Posts
