Yet I have found another good arguable topic
What are the pro's and con's of both a Spring + Strut Combo & Coil-Overs
If you have any of these type's of setup, Treat this like a reveiw and tell us what you do and don't like about it
BTW IDK if this should go into the Wheel,Tire, Susp. section well let a mod decide
ALright here we go so far:
Spring + Strut Combo:
Pro's:
- More Veriaty (sp*)
- Put together your Own kit
- Some manufactures can make better Springs/Struts then the other
- Cost
Con's:
- Some apps lack adj.
Coil-Overs:
Pro's:
- Large Range Of Adj.
- Better Psring Rates
- Better Dampening
Con's:
- Cost
- Sometimes Only Height Adj.
- Ring's Can Lock-up w/ Dirt - etc.
Pro's:
- Cost
Con's:
Coil-Overs:
Pro's:
- Better Dampening
Con's:
- Cost
