Loofee95SE said:
If your goals is 350 HP, go with Sr, u can get there faster and cheaper with SR. the CA will only make 280 hp with T28, and not safe for the internal after that. I own CA18det and I love my engine. but my goals is for only 250 Rwhp. so....do your research...and see what do u want..if u really need that 350 hp..but hard to get parts go with SR, and if u thing 280 is ok for everyday driving and u can just go to Advance auto part or Nissan dealer to get parts..then Ca is for you..just my.02 C
How high was boost on the T28 to make 280hp? I have been researching both motors at different forums and found that the CA18DET can hold most boost than an SR20, because it is an iron block instead of Aluminum. Also CA18DET has much better head design compared to the SR20. Then again the SR20DET has .2 Liters more displacement
I am not dissing on the SR20DET its just some info I found
__________________________________________
1994 GMC Sonoma V6
Custom exhaust, K&N Intake, Accel Performance Distrb Cap/Rotor, JBA Racing Plug wires, Bosch Plat 2 plugs, Castrol syntec w/ K&N oil filter, 2000 xtreme rims, PIAA extreme white lights.
1992 Nissan 240sx SE Coupe 100% STOCK. New Project
Mobil 1 Synthetic w/ K&N oil filter, NGK Iridium IX Plugs
