1 - 6 of 6 Posts
I have a 91 240sx sr swap. And today I went to start it. When I turned the key, nothing. The battery is charged. It could be a starter but I have feeling its not. Any ideas on where to start? Any help is greatly appreciated.
check connection to starter. if thats good then check the connector that is bypassed, make sure its not loose. If thats all good then check all fuses.
Well I just checked the starter it appears to be good. I checked for voltage on the main power to the starter and the one that goes to the solenoid. I got 12 volts on both. Seems like everything should work.
Discussion Starter #5
Yeah its plugged in but Im only getting like 11.5 v there. Do you think it could be high resistance in the wire or something. I jumped power from the main terminal on the starter to it and the starter worked so I know thats good. Is there anyway to get a new connector for that?
1 - 6 of 6 Posts
