1 - 3 of 3 Posts
I have a SR20DET and needing a new head gasket, what are the specs on the SR20DET so i know what size of a head gasket to get? thanks
what do you mean what size you need is your engine stock, has it been bored over, does it have a stroker kit???? if its stock you can use a 11044-40F00 head gasket from your local nissan dealership, i just checked i work in nissan parts its a good part number in the U.S. , if your needing to know the bore stock is 86mm, if its been bored over .020 you will need an 86.5mm gasket, .040 over you will need an 87mm gasket
1 - 3 of 3 Posts
