1 - 3 of 3 Posts
Ka24de
So my fuel pump not priming, I checked the plug for current and there's none going to the pump I check for voltage on fuse box "egi pump" 2 of the wire have power when ignition is on, Still nothing on black and yellow that's suppose to go to the pump... do I have a bad relay? Pump was working fine b4 till I dropped This ka24de. Only thing I here when I try to start is a clicking noise? ? So any thoughts? What cud it b not well grounded?
The clicking could definately mean its not well grounded i had the same problem does you battery terminals have corrosion on them? as far as the fuel pump im not sure. mines gone bad before but you could tell it was the pump not a problem with power to the pump.
Discussion Starter · #3 ·
Update. I think it may just be the relay. Becuz I got power from black and white cable and connected it to the black and yellow as soon as I switched the ignition on I herd the pump. Guessin the relay ain't doing its job
1 - 3 of 3 Posts
