1 - 3 of 3 Posts
When Starting my s13 I sometimes have to pump the clutch or it won't start. Sometimes it starts easily, sometimes I have to pump the clutch a lot of times and then it will finally start. Does anyone have any ideas on what can be causing this? Or has anyone experienced the same problem? I would appreciate the help. Thanks.
I have the same problem,changed the clutch safety switch under the clutch peddle, new starter switch with key,am thinking I have a bad spot on starter
1 - 3 of 3 Posts
