1 - 3 of 3 Posts
Hey guys,
I finally got my RB25 all aligned and bolted down. I'm running in the normal problem of the steering shaft rubbing again the turbo elbow. I tried grinding down the elbow already, no luck. I looked up the syko turbo elbow, and it seems like its a good fix. But from the looks of it, it appears you can't use your stock internal wastegate? I've tried searching but no luck. Anyone using another elbow or find an alternate solution? Thanks in advance.
John
I have a custom 30r setup on mine so I'm not using a stock elbow. I used a blow torch and a welding hammer to dent the pipe a little were the shaft was rubbing. I only had to dent it in about a mm to make enough room.
1 - 3 of 3 Posts
