stock sr20det 12psi??
4338 Views 7 Replies 5 Participants Last post by  unreal-
does anyone know what kind of horsepower a completly stock sr20det redtop with pullys, 2.5in exahust would produce at 12psi and an estimate of quarter mile time???
Status
Not open for further replies.
1 - 8 of 8 Posts
Dyno it. There could be all sorts of problems with you car, so it's impossible to say.
Take it to a track and find out. For all we know you could drive terribly or something could be wrong with your car.
im talking theroetically
There are so many variables, no one will be able to tell you. Depends on what other mods, depends on which turbo you are using to push out the 12 psi. Oh, and get rid of your 2.5 inch exhaust, that will restrict you. I really hope this thread gets locked, it's going to go nowhere. Search google, if you want to find some results. Just type in the mods you have and look for a dyno chart.
haha FUCK YOU, you ***
stock sr running good has 7 lbs at about 200 so 5 more lbs adds how much, in basic terms?
wow, that was uncalled for. He gives you a bit of info, and search keywords to help you out, and you say that?
Watch what you say around here, or you'll get a vacation. 1st time is a warning.
What RLong said was correct. You cant ask such a generic question without a lot of additional information. As it depends on a crazy amount of variables, and even the same car with the same mods, same weight, same track temp, same track prep, same launch rpm, same slicks, same psi @ turbo and tires, and same amount of gas can run different times.
Before i close this, If you searched the internet, youd know that a stock SR'd 240 usually runs mid-low 14s stock. 13s if you have FMIC, upped boost, slicks, LSD, etc.
Thanks for the heads up Rlong.
/thread.
1 - 8 of 8 Posts
Status
