1 - 20 of 89 Posts
Premium Member
I have seen Many threads asking whats the spec's of the stock turbo's and what they are rated at so....
Note: The HP ratings are w/ Fully Stock Motors
S13 Red-Top T25:
Compressor: T-25, 60 trim 56mm 0.80 A/R BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Stock Boost: 7 psi
Safe Boost: > 13-15 psi After that The Turbo is past it's efficiency
Max Boost: 17 psi
HP Ratings: 240 - 250 RWHP
Type of Bearings: Journal Bearing
S13 Black-Top T25:
Stock Boost: 7 psi
Max Boost: 17 psi
S14 Zenki (1993-96) Black-Top T28:
Compressor: T-28, 60 trim 60 mm 0.60 A/R BCI-1 compressor in T-04B housing
Stock Boost: 7 psi
Max Boost: 17 psi
HP Ratings: 250 - 260 RWHP
Type of Bearings: Journal Bering
S14 Kouki (1996-98) Black-Top T28:
Stock Boost: 7 psi
Max Boost: 17 psi
HP Ratings: 255 - 265 RWHP
Type of Bearings: Ball Bearing
S15 Black-Top T28:
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing, Inconel Turbine Wheel.
Stock Boost: 7 psi
Safe Boost: > 15 - 18 psi After that The Turbo is past it's efficiency
Max Boost: 20 psi
HP Ratings: Approx. 300 RWHP MAX
N14 GTi-R (1990-94) T28:
Compressor: T3 Super-60, 60 trim 60mm 0.60 A/R BCI-1 compressor.
Turbine: T-25, 79 trim 53.8mm 0.86 A/R turbine housing, Inconel Turbine Wheel.
Stock Boost: 7 psi
Max Boost: 17 psi
HP Ratings: 290 - 300 RWHP
Upgrades: Replace compressor Housing w/ S14 T28 and Max RWHP can be bumped upto 320
Updated: 1/11/09
Premium Member
Haha... Nice post Scott. Who knows... You might have saved a lot of people from posting about this in the future. :D
Premium Member
Yea he is... Don't let him lie to ya.
Premium Member
Not I said the green duck... But I'll sticky this for ya to save future newbs the flaming.
Premium Member
Discussion Starter · #9 ·
^What other mods did they have?
BTW I just read up on it again and it's rated at 270-280 but not 300 :12dunno ?
BoostedVR4 has a S14 T28 w/ AEM EMS making over 290whp i believe. I dont think you should put the HP ratings of the turbos up since engine setup is going to have alot to due with it. With an ECU Tune, Larger injectors, and Z32 MAF the T25 will go over 250whp. Check my cardomain at my current setup and tell me you dont think I can get over 250whp. I never had the car dynoed but it did a 106mph in the 1/4 before i did the injectors, maf, enthalpy tune, and cams.
for the S15 T28 how come you put safe boost 15-18 then put Max boost at 17. Doesnt make much sense? Max boost would really be what the turbo can push with the vacuum line off. In that case my T25 pushed 1.5 bar once when the vacuum line popped off my boost controller.
good post.
the hp ratings for those are whenever the turbo is still in its efficiency range. you can always make more power, but the turbo is just out of its efficiency range, which is bad for the turbo as it is spinning way too fast, and also heating up the air way too much which is why the power gains arent as good. if you dont care too much for your turbo though, or if you just do it on race gas every now and then, it should be fine. i got a friend who's been pushing 22-24psi on a little 14b for a very long time.
what i still cant figure out though is how the s15 t28 has the exact same specs as the s14 t28, but has an efficiency range good for higher boost. guess i just need to read up more about why that is (if someone finds out, post it here, id love to know).
FYI there are different versions (for different international markets) of both the s14 and s15 t28's. Different bearings (CHRA's) and one of the s15 versions had a seperator in the exhaust flange.
For example the Australian market never got the BB s14 turbos and only a few s15's got the BB version but were retrofitted with s14 parts instead.
here are the part numbers
Jap PS13 14411-50F00
AU/NZ S14 (pre-facelift) 14411-75F00
AU/NZ S14 (facelift) 14411-75F00
Jap S14 (pre-facelift) 14411-69F00
Jap S14 (facelift) 14411-82F01
Jap S14 (Autech/270R) 14411-RP801 (Same as S15 early MT turbo)
Jap/ NZ S15 (early*) 14411-91F00 Manual model only
Jap/ NZ S15 (early*) 14411-69F00 Automatic models
Jap/ NZ/ AU S15 late* 14411-75F00 Same as NZ S14 and same for both Auto and manual
didnt you for get the gti-r t28??? That turbo w/ an external wastegate will hold 18psi and get you 320whp.
sorry didnt see the stock motor part, no, i had it right, so your telling me that a gt28r is good for 300hp on stock motor, i think i would like to see those dyno charts
im running 1 bar with my current setup and it spins wheels all the way to 60mph when it didnt use to at the same boost with my stock setup. Boost can get you so far but adding engine mods on top will bring the power up even more, even at the same boost levels.
1 - 20 of 89 Posts
