1 - 4 of 4 Posts
· Registered
93 nissan 240sx S13 5speed SR swap
hey guys......little help,,,,was driving and accelerated was not a hard one and there was a pop.....so i creeped back home
and looked around the engine bay....the turbo had oil on it.....i changed the injectors and coils.....checked for vacuum
leaks and fuel filter.....engine runs a lot smoother but....still runs rich....so what is my next move.
· Registered
Discussion Starter · #3 ·
POP WAS FROM ENGINE BAY....CAR SMELLS LIKE RAW FUEL....THERE IS OIL INSIDE OF INTERCOOLER AND ON THE TURBO.....I PULLED THE HARNESS CONNECTORS FROM INJECTORS 1-3 WAS A CHANGE IN ENGINE PERFORMANCE.....#4 WAS NO CHANGE....I PUT NEW INJECTORS IN AND SAME SYMPTOMS...NO I HAVE NOT CHECK ECU.....IM LEANING TOWARD A NEW HARNESS ITS ORIGINAL TO MOTORSET.
· Administrator
Do you have a consult port reader?
Basically I need you to verify all the sensors are working properly. MAF, coolant temperature sensor, TPS, etcetera.
I will make another post about what you need to buy ( $20 adapter, download some free software on your laptop)
Make sure your oxygen sensor is reading correctly.
Can you verify the fuel system is correctly holding pressure and you have no leaks?
I also suggest you check for any exhaust leaks.
As far as oil in the intercooler, that may be a sign that you have a blown oil seal on the turbo.
Do you have the factory hardlines for the turbo or are you using aftermarket lines?
I ask because a lot of times, when using aftermarket, people don't use a proper oil restrictor on the oil feed line and too much oil at too high of a pressure make it to your turbo, blowing out the seal.
On the oem hardlines, the banjo bolt has a very small orifice for the oil to pass through.
Some aftermarket lines like this one
use the factory banjo bolt and others do not.
Your changing out the injectors makes sense.
I would not immediately think that the harness is bad.
If your car runs fine but just smells like gas, it could be either your car running very rich due to a bad sensor OR you have some nasty exhaust leak.
1 - 4 of 4 Posts
